ok so im finishing up a knife for a buddy that i had planned to give him this following thursday. last night handle was fine. Today i went out to do some final touches on the handle and it pretty much seperated from tang all the way around. The wood is cocobolo. the glue side was sand down with 36 grit belt and i even drilled some very small pin holes for epoxy to set up in. i literally scrubbed the wood with acetone till no more color came off on rag then i preceded to do the glue up. the tang was done to 36 grit freshly sanded and cleaned with acetone. gloves went on after cleaning and no bare skin touched any glue pieces. the handle has 2 pins in and those were glued in also. It appears that the pins at this point are the only thing holding it togther. i guess my only downfall i can see was maybe the epoxy was bad or not fo good quality . it was just standard loctite 60 minute 2 part epoxy. i have used it before with no problems. one other thing i did was color the expoy black with mixol from woodcraft which was a new thing for me so maybe that was the probleam? Either way is there any way to to salvage the blade since its a real cutter. i was thinking i could maybe boil the the handle off and start with some stabilized wood which i normal use. any help would be great since i dont have time to start over and have rdy buy next thursday.
