Danish Oil application method one – the ‘wet on wet’, single day application method.
This method allows Danish Oil to be completely applied during the course of a single day, and the wood to be ready to use after 48 hours.
The idea of this method is to keep the wood surface’wet’ with Danish Oil for at least an hour until it has fully absorbed enough oil to provide a natural protective coating from deep within the wood.Above are two oak chopping blocks for illustration, prepared for oiling by sanding with 80 grit sandpaper. We took one block and first of all applied three liberal lots of Danish Oil immediately one after another using a lint-free cloth until the block stopped absorbing and remained looking ‘wet’:
After 20 minutes we returned to the block and repeated the application above:
After another 20 minutes we returned and applied more Danish Oil. By this stage the oil was not soaking in very much and the block was looking really wet, with an obvious coating of oil on the surface: After another 20 minutes we returned and removed all the remaining Danish Oil from the surface with a clean rag:
The board was left for one hour and then wiped over again to remove any oil that might have exuded back out of the pores of the wood. If there were any obvious dry areas we would have used more oil on just those areas at this stage.
After another hour we wiped the board again, although there were no obvious signs of surface oil at this stage and the board was dry to the touch, with a pleasant low sheen finish.
The board was left at room temperature for 48 hours before it was used to allow the Danish oil to cure.
Any ‘nibs’ or dust on the surface of the wood during oiling cannot be removed with this method of application until the wood has been left to dry for at least 24 hours. The particles should then be removed with a very fine grade wire wool (oooo grade).The performance of Danish Oil will continue to improve naturally for a week or two after application. We recommend that wood should not be subject to heavy use, and any water or other spills should be wiped off immediately during this tim
