Thanks all for chiming in. Some thoughts...
You ponder that speed should equate to power but you can not forget about momentum a light fast blade although easy to pick up speed can not compare to a heavier blade with weight that might be slower to change direction and get moving but will have more power and hit like a freight train.
I pretty much agree with what you're saying, however, that's not what I was talking about. Or at least, I think they weren't talking about anything to do with blade weight. (but that's why I'm here asking for clarification) See my post directly above yours.
396vette said:
IMHO,from personal experience not physics mind you I would agree with this point.
That would probably be one of the reasons for skeletonized handles- to get the weight out of the handle.
For what it's worth, in general terms I disagree with what Gene said, and so do at least some of the competition guys. I think it was Daniel Winkler who has said several times to taper the tang (reduce its weight) for balance and speed. That is, in this case, the blade is faster and more natural to manuever when the balance is shifted
forward. I have written much on this subject in the past; probably in the review and testing subforum.
Lorien said:
Here's an example,
http://www.valiantco.com/java/GolokJonggolM.JPG, of a straight, fairly narrow blade profile that generates lots of power due to the curved handle. I have this and use it lots. The curved handle angles the blade in such a way as to create a lot of shearing force. By this I mean that as the object to be cut is hit, it is essentially riding up the ramped edge that the angle between the blade and handle creates.
I was also wondering if this is what they were getting at- the curved handle changes the angle the blade/edge is presented to the target. But I'm still not sure why that would slow down your swing. ? I do agree that the curved handle forces the blade into more of a straight shearing cut, as opposed to the "draw cutting" that is easier with a straighter handle. I disagree that there is much riding up the edge toward the handle, at least from what I've seen messing around with my khukri. But even that only really works if you're striking way back on the edge in the curve, so right off the bat you're sacrificing some power that could be had by hitting further out.
Lorien said:
Momentum is a powerful force indeed, and is difficult to stop as the weight increases, making a blade less easy to control.
When the handle is curved and the blade is straight, you lose some power compared to a knife like this,
http://www.thekhukurihouse.com/catal...f87&image=left,
where the blade is curved and the handle is straight. However, the tradeoff is that the blade can twist laterally more easily
Again, they didn't sound like they were talking about changing blade curvature and weight (i.e., changing everything until you have an entirely different knife); only handle curvature. I don't recall seeing any of the competition guys using khukris lately.
I agree that a handle heavy knife is easier to control, interrupting the momentum mid movement is not difficult because the weight of the blade is not effecting your wrist and robbing energy arresting the movement.
Without wasting a bunch of bandwidth here, in short I think it would be easier to say that "handle heavy" vs. "blade heavy" is too simplistic an approach.
Kevin Jones said:
This Gamemaster is designed for good power for cutting through bone and cartilage.
That knife was designed for fast and powerful chopping?
Broos said:
When you say power and speed, I think of chops or cuts made with a swing.
Yes, sorry to Kevin above; I should have made that more clear from the start.
Broos said:
Or do the most powerful cuts involve actually delivering forward force to the cutting blade during the cut? I can see this with a two handed type blow with a sword (or a hockey slap shot), and I think you can deliver this force if you time the wrist snap right before the edge impacts. A large sword with a weight at the handle end (is it called a finial?) could deliver additional energy to the cut by adding additional momentum around the pivot point, too.
At least regarding one handed stuff, the longer the blade gets, the less leverage you have on the tip. You're relying more and more on the blade to do all the work since your hand/wrist doesn't have the leverage to add much power during the cut. (this is why we
chop in the first place) I think "pommel" may be the word you were looking for. Thanks for mentioning the pivot points in relation to it. I've often wondered why the competition guys don't make use of this more.
Broos said:
Does one handle angle allow you to obtain higher velocity than another? Or does the handle angle allow you to better deliver energy from your hand into the cutting edge during the cut? I think it would be difficult to show how you can generate more velocity with a slightly bent handle than you could with a straight handle from a purely scientific basis. It's going to come down to skill, ergonomics, and comfort ruling this decision.
This is exactly what I'm wondering. Either the handle is shaped to allow your hand to apply maximum power, control, and speed to the knife, or it isn't. (well, basically.) I have no doubt this will vary by individual for the reasons you mentioned.
Maybe I'm making much ado about nothing here. If anything it's beginning to sound more and more like I misunderstood what the authors of those comments were getting at, and it's really nothing out of the ordinary at all. But either way thanks all for a lively discussion.
