I’m new to sharpening and have the Hapstone R2 with the angled clamps. What I’ve noticed on the last couple of knives is that I’m getting uneven edge bevels, one side has a wider edge than the other. Is this because of ffg blades? I’m trying to clamp on a square cut part of the tang where possible. Is this just to be expected with ffg blades? Besides cosmetics, does it really matter? Thanks.
cudgee
is almost there to hit the nail on the head for you with what he said about the factory grind. Not necessarily only because one side may have a different angle, as ground from the factory, but more likely because the edge is not in the center of the blade.
Imagine for a moment a tall rectangle with its top cut off on both sides to form a point. You can easily cut both sides of the rectangle at exactly the same angle, but you can cut one side off smaller than the other side. To form the point, you now cut the other side of the rectangle off at the same angle as the first small offcut, but a much bigger section. The top of your original rectangle can still have a perfect point with (for example) 15 degrees on both sides, but that point can be almost completely to one side.
Think of how a chisel is ground as an example of this done on purpose. All ground on one side, and the edge is completely off to the one side. You would want that type of grind in a chisel, but not necessarily on your favorite EDC knife.
Most knives, as they come ground from the factory, have extremely inconsistent and uneven bevels. It's definitely not an issue with your Hapstone system at all. The incredibly slight change in angle measured when you flip your rotating clamp over will NOT make any real significant difference at all. Don't measure and re-adjust the sharpening angle every time you flip the blade. This is NOT going to solve your problem at all. By doing that, you will be chasing your tail in circles and you won't get as good of an end result. DO measure your angle on the same side of the blade every time you swap stones, but NOT every time you flip sides.
BTW, you are clamping your FFG blade correctly by using the flat tang area for one clamp. This is the best way, keep doing it that way.
What you need to do to solve your problem, is spend a lot more time with your low grit stone to grind the smaller bevel further back, until it is about the same size as the bevel with the bigger side. This will then bring your edge into alignment with the center of the blade, with even bevels on both sides.
FYI, it's actually also a very common mistake a lot of guys make when they spend too much time re-profiling one side of a blade alone until they feel the burr on the opposite side, then when they finally start reprofiling the other side, the edge is ground out of alignment with the center of the blade. That's why (if you do it incorrectly), you could sometimes get the burr on one side much quicker than the other side when you re-profile a factory edge.
I suggest spending a good amount of time re-profiling and aligning your edge with the bevels ground visually the same on both sides. When you do this, don't be hasty when you feel a big burr forming, just keep going until your bevel is even, then continue sharpening normally after this. This will solve your problem.
