- Apr 3, 2013
jertex contact Konstantin at Gritomatic he has the Aluminum blanks,you can either purchase brand new blanks from his website that have nothing engraved on them or if you wan to save some money contact Konstantin and ask him about the aluminum blanks he has for 1 usd each they are ones that have the grit's engraved on them and it's a take what you get deal just use a sharpie to write the grit on them.
To attach the stones just buy some 3M Super 77 spray,just spray a good coat on the blank and wait the time it say's on the can then press the stone into place and your done,the 3M Super 77 spray is what others use when they make stones to sell mounted on blanks,I have soaked stones for a longtime mounted with that spray and they never come loose,also using the spray is very fast and easy you only need to hold down on the stone for 6 to 10 seconds max and your done.
I prefer the stones mounted to blanks myself.
I was referring to the problem of them moving since they aren't glued to any backing of any kind. I've seen stones that are attached to what appears to be a thin aluminum backing that latches into the clamps more effectively but the stones that come with the V7 don't have this backing. I will try your advice on moving the front block back toward the handle to increase the spring pressure to see if that solves the problem. If not, I'll probably return it.
