- Jun 19, 2018
Good morning all, I am making a 6 brick hard fire brick forge with single venturi burner that will be able to run at max 20psi. The hard brick is all I have access to for the immediate future to hammer on some steel, and have read conflicting advice on coatings. Assuming no kaowool liner, would itc-100 or some rectory cement increase efficiency enough to reach forge weld temps? ...Or should I leave everything as is knowing it'll be enough to heat steel to hammer out and reach critical temperatures for heat treat, then build something more efficient when I outgrow this one.
