Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I'll try and sum it all up for you:
1) The bricks you listed are fireplace/wood stove lining bricks. They are designed to take the heat without shattering, and absorb the heat to radiate out into the room.
2) They would need a LOT of heat from a propane burner to heat up to knifemaking temperatures.
3) Wrapping a hard brick forge with kaowool won't change the above issues. It would take a BIG burner and a lot of propane to heat the bricks to 1500F. This is basically how a blast furnace is built.
4) Lining the bricks with a layer of kaowool, a satanite coating, and ITC final coat would work ... but the bricks are just the shell and not doing anything. Any tube of non-flammable material would work just as well. Thin sheet metal, a piece of large pipe, a coffee can, a metal waste paper basket, even rolled up chicken wire would work to hold the wool.
5) Soft firebrick is what many folks use to make a 1,2,4,6 brick forge. All you need is the bricks, some bailing wire or other method to hold them together snug, and a burner. A drill and a 2.5" hole saw will make the holes perfect, but you can cut them with an old steak knife. There are many old threads in Shop Talk on making these simple forges. The search engine in the Stickys will find them for you. There is also a lot of good forge and burner info in the Stickys.
6) Hard fire bricks can be used as the pan liner for a solid fuel forge. There is a lot more to build, though. Lump charcoal (not charcoal briquettes) or forging coal (Pocahontas #3) is the normal fuel.
7) A propane forge is much easier to use ( especially for a beginner) than a solid fuel forge.
