I recently got in some Fallkniven A2 knives & have them at a good price. Check them out here: http://www.the-knife-connection.com/fall-a2wk.html
When you are really far from inhabited areas, you need to be able to rely on your equipment. Some things just have to work, despite everything. The Fallkniven A2 is an example of a knife of extreme durability that will never let you down, a knife that can stand up under incredible strain. The reason for its remarkable performance is that we use a newly developed laminated stainless steel, with an edge consisting of our now-famous VG10 steel and with sides consisting of resilient 420J2 steel. The combination of these different kinds of steel gives a blade which keeps its edge well and which is extremely strong. Since we supply this knife with a convex edge, it is suitable both for cutting and striking. For expeditions and tough outdoor use, the Fallkniven A2 is the obvious choice of serious outdoorsmen.
A high quality belt sheath is included.
Knife Type: Fixed Blade
Blade Type: Modified Drop Point
Blade Thickness: .236"
Tang: Full Length, protruding
Origin: Japan
Total Length: 12.75"
Blade Length: 8"
Weight: 13 Ounces
Handle Material: Kraton
Blade-Steel: Laminated VG10
Rockwell Hardness: 59 HRC
Warranty: Two Year Limited
Origin: Japan
Blade Length: 8"
Weight: 13 Ounces
