- Dec 21, 2006
After reading a recent thread that I'm sure all of you know and I dont need to reference with much else, I have observed that there are some very heavy opinions on the subjects of hard use and abuse. Many of these posts, however, were devoid of any explanation of what is considered hard use or abuse. I will note that I noticed that more on the hard use camp. So I have decided to try to clarify this a bit and try to form a working consensus on what constitutes hard use and abuse using the opinions of members of this forum. I may well fail but at least i will try.
Here are the definitions and examples for me. (restricted to folders for the most part)
Hard use: Cutting hard to cut materials or materials that would cause expedited dulling. For example: Wood, carpet, thick plastic, wire(could cross over into abuse), sheet rock, rubber hose, thick rope and the like. Light battoning with a well built unlocked folder is walking a fine line between hard use and abuse in my opinion and is one area where I believe the opinions would differ the most. Penetrating materials that will be cut such as thick plastic packaging.
Abuse: Any activity that would apply force to the spine of a knife (with the exception of removing the knife from a bind in a cut, striking a fire steel, and stabbing soft materials). Heavy Chopping with a folder. Batoning a locked folder or heavy battoning on an unlocked folder. Prying. Applying force to the knife with anything except your hand and own muscles (previous exceptions are still exempt).
As far as the need for a strong lock, why do you or dont you need an uber lock? Have you ever had a lock fail during use? If so, what exactly were you doing? Do you consider it hard use or abuse?
I have no need for an uber lock. I never put force on the spine of a knife in the direction of a lock. Even in a self defense situation I don't see how too much force can be applied in that direction with proper use. I have never had a lock fail or even a slip joint close on my fingers.
Please try to keep the comments civil... we shall see if a flame war has been started
