Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
When they say mix for a minute, they mean it.
This is very important. The chemical reaction will start very rapidly if you leave any concentrated areas in the mix. Mix well with a popsicle stick. A box with a lifetime supply can be bought for a few bucks. Mix in a circle, reverse direction, mix crosswise, and then back in a circle again. After you are sure it is fully mixed, mix it a little more. As Willie says, most problems are caused by improper mixing.
The ratio is also very important. If it says to mix 1:1, then make sure the two puddles are exactly even. Using a gram scale is more precise. Most resins aren't exactly 1:1 by weight, and many good resins have the weight ratio marked. If there is no weight ratio marked, 1:1 is usually close enough. The lowest ratio I have for a resin is 100:84 (resin to hardener) and another is 100:97.
I use the small cups that you get for take out of catsup and sauces. Don't steal them from McD's, buy a box at Costco or Sam's. A case will last ten makers three lifetimes, so try and get a few friends to go in on it.
Add the resin to the cup first....never the other way around.
Mix in the cup for 1 minute, and then pour into a wide plastic lid or pan. If doing one handle I just work from the small cup. But, when doing multiple handles, I use 24 hour epoxy and a wide container to do 20 handles or more in one batch of resin.
