- Jan 5, 2005
How do you guys accurately test the hardness of your blades ? I've been thinking about this for a while and Sams post "1095 Problems" prompted me to finally ask.
The obvious answer would be a Rockwell tester, which I have. Common sense tells me that deflection due to blade bevels makes for a less than perfect set-up for accurate results. Testing on a flat surface that may or may not exist on any given knife is usually too far away from the edge that I'm concerned about testing. Hollow ground bevels also create a unique set of issues for accurate testing.
Would a custom sine plate type anvil for a tester work or do you think there would be too much of a "mushy" factor ? Would a convex shaped anvil work for hollow ground bevels ? I'm beginning to think that the hardness testing file sets sold in various supply catalogs may be more appropriate ( or accurate ) for knifemaking applications. What are your thoughts, solutions etc. when it comes to accurate testing of your knife blades ? Thanks for any help or suggestions you can provide.
