I have one. Haven't reviewed it publically though.
I will say this. I have passed it around a bit and tested it cutting against the JunkYardDogII, StormII and JYD. Of the three cutting 1/2" hemp rope, cardboard, and old carpet pulled up from a kitchen the JunkYardDogII is the best performer of the ones I have. All were tested right out of the box with factory edges.
I noted that the Groove, and Storm were both quite uncomfortable after about 25 slices in the hemp rope which forced me to continue on to 50 by putting on gloves first. Surprisingly the JYD and JYDII both were quite comfortable and capable through all 50 cuts. I noted the edge was thinner and the bevel angle steeper on both of these making them effective slicers compared to the rather obtuse factory edges that were on both the Groove and the Storm. I felt at first that that grooves on the blade of the Groove were causing undue friction, but after getting it back good and dull from several people handling it I finally put a new bevel on it with the Edge Pro at 15 degrees per side. I used the 120 grit stone first, then followed that with the 220 grit followed by one swipe each side on the 1200 grit ceramic rod.
The difference in performance after doing this was night and day. Its now up with the JYDII if not better at cutting all the above mediums and this time with 50 slices in the hemp no gloves were even needed as it was effectively slicing off clean cuts of the hemp with relative ease compared to the first run.
Of the four the Groove is the one everyone just loves and goes nuts over. I could have sold it five times over by simply consenting to let anyone of the guys I let use it buy it from me for a quick profit too since at the time they were not readily available. In the looks dept. the Groove and the little JYD with the Air Force logos are both winners. The Storm was the least favored in performance and looks over all of them and the flipper on the Groove makes the others look and feel less adequate. The Groove is the only one that you can flip the blade out on easily with no additional wrist flick help like needed for all the others and this is true of the Groove even when holding the knife straight up so the blade has to go against gravity to lock into the open position. It flips right out with nothing more than a movement of the index finger by itself. I can't duplicate this with any of the other knives with flippers I currently own.
Opinions on the pocket clip on both JYD folders is about 50/50 at this point. Seems there is no gray area with it as folks either absolutely love it or hate it. On my Groove when I went to flip the clip to tip up carry the G10 over scale prevented the clip from seating and required my taking the scale off to sand down the extension on it so the clip could be mounted. I noted that the pocket clip covered the lanyard hole a little once screwed down into the final mount position for tip up carry. Both of these things were reported to Thomas Welk as soon as I noted them and he took immediate action to fix it on their end but I understand a few got out before it was remedied. Neither are anything major or that hard to fix on your own though.
I have to say I really like the Groove. It has a great balance, the G10 overlays are quite nice for perfect grip but not so aggresive that they tear up pants and of cours as already noted its a real head turner for looks. Not the kind of folder you want to lay down and turn your back on for long thats for sure.
The flipper operation of the Groove is simply the best I have ever used and is certainly as smooth as the nicest customs I have bought in recent years. For the price any of these recent knives to come out by Kershaw are very good values. Get one you won't regret it. I kid you not when I tell you that you could buy a production knife for three or four times the money of any of these Kershaw knives and not get as smooth an operating knife or as precise machining. Kershaw has really done something wonderful here with all of these. And the fact that each is affortable, and made in the USA really puts Kershaw up in the very top of my rankings for favorite companies and favorite products.
I like all of these knives. The biggest problem with having all of them is not knowing which one I want to carry from one day to the next. The JYDII and Groove are currently seeing the most pocket time but ask me again next week and I'm sure I'll be carrying something else. Especially if Thomas and Kershaw come up with something new that I see that strikes my fancy.
I have found test results of knife makers using Sandvik steek and bending it to a set, and then bending it back to straight with no harm to the blades which shows wonderful toughness akin to some of the carbon steels if you ask me. I can tell you from using it that all of these knives from Kershaw have wonderfully stable edges that reflect very little light back along the edge, have never chipped out or shown any real problem areas to me even after very heavy abusive cutting with them at times and overall have moved up the Sandvik rankings in my ratings of blade steels in stainless right along with Kershaw. The blades of this 13C26 stainless sharpen up easily, and perform quite well from course slicing edges to extremely highly polished stropped ones and they hold the edge you put on them very well.
STR
