I am getting close to a supplies order and am debating ordering some Rhynowet. It seems to be the preferred brand with lots of gushing over it in nearly every thread I read. I have not liked the 3M wet/dry paper or anything else found locally thus far except Gator Red Resin. I searched and couldn't find any references to it on here, does anyone else use this stuff? If so and you have also used the Rhynowet, can you please give me a comparison of the two as to performance?
(I have moved from files to an early 80's model Craftsman 4 x 36 sander to profile after hack-sawing the pattern out, and then to grind the bevels in as close as possible to their final shape. That is with an 80 grit Norton Zirc belt, then I start sanding at 120 grit with a steel bar or an old Great Planes T bar. Then 220 and 400 pre-HT. In case how I'm doing it matters and in case anyone has any recommendations or suggestions as to my method thus far. I'm new and all ears.)
