neetones said:
Could you post your methodology with the Edge Pro? I'd be really interested to see what details I'm missing, particularly how you deal with the burr.
Lately I've been using the Sharpmaker and working my way up to the ultra fine rods and then stropping. Stropping seems to be the key. It helps to polish and align the finished edge. If you were to look at your edge under high magnification you'd be surprised at how bumpy, scratched, and chipped up it looks. When you strop it helps to smooth all that out, although even a stropped edge will look far from perfect under high magnification. These seems to help you reach a sharpness level that will shave hair above skin level, slice through toilet paper, etc.
People here have all different ways to strop. Some just use cardboard, or rub compound onto the cardboard. I like my strop block from knivesplus.com:
http://www.knivesplus.com/KP-STROP8-STROPBLOCK.html
Seems to do a good job, and they take care of all the messy work of loading the leather, conditioning it, etc.
Learning to strop properly takes a little practice.
With the edgepro, and edgepro only, I would reprofile the knife to at least 15 degrees per side. You can go up to a mirror finish if you like, then put a 20 degree per side micro bevel on. If you already have an edge going with 15 degrees per side it won't take many strokes to put on a 20 degree per side microbevel with a fine stone. Maybe start with the extra fine or ultra fine stone, then finish with the polishing tapes. Gotta be sure to take very light strokes and don't put pressure on the stones. Let the stones do the work, and the polishing tape. If you put to much pressure on the edge you'll roll it and screw it up.
If you want to go sharper simply reprofile to something less than 15 degrees per side and then put on a 15 degree or less per side micro bevel. Some guys here go really thin, like 7-10 degrees per side and a 12 degree per side microbevel, or LESS, crazy fools!
j/k guys
How thing you go depends on what kind of steel you are working with and what you want to use the knife for. I like my knives really sharp, but I also want them to hold their edge for awhile, so I stick with the 15 degree per side bevel and the 20 degree edge. I often use the Edgepro to reprofile to 15 per side, and many here will say using an Edgepro for this purpose is overkill and a waste of it's abilities, but I find it does a quick and accurate job of reprofiling, nice even bevels. Then I'll put on the 20 degree per side edge with the Sharpmaker so I can easily return the knife to it for touch ups, rather than setting up the Edgepro each time I want to touch up the knife.
I'm still learning and there are always people here pushing to get a sharper and sharper edge.
