- Jan 30, 2014
I am grateful to have gotten the chance to be a part of the Fiddleback mid tech Hiking Buddy pass around review. I had the hiking buddy for a total of about 10 days. I put it straight to use and was able to take it on a week long trip to a cabin in the Trinity Alps of California. I used it for a variety of tasks that I felt were suitable for a knife this size. Everything I did with it were normal things I might use a fixed blade edc for.
Here are the dimensions of the knife quoted from one of the retailers. It retails at several sites for $195.
Profile Name: Hiking Buddy
Handle Material: Black Canvas Micarta
Overall Length: 7.24 Inches (184mm)
Blade Length: 3.2 Inches (82mm)
Weight: 3.9oz
Thickness: 1/8" - Full Tang
Steel: S35VN
The packaging on the Hiking Buddy is very nice. Out of the box the finish looks excellent on this one.
The leather sheath it comes with secures the knife well. I held it upside down, gave it a good shake and it did not fall out.
The most important thing for me in a knife is the cutting edge. Knives are meant to cut and I like ones that cut easily and efficiently. I like a sharp edge that bites into wood with little effort. If I have to apply a lot of pressure for a knife to work, then I don't want it no matter how pretty or burly it is. The first thing I do when I get a knife is check for symmetry in fit and finish. Next, I like to cut some paper and see how sharp it is. This hiking buddy has been used by others in the pass around so it was not a reflection of how the knife came from the Forge, but it was sharp enough to cut paper without a problem. A couple passes on the strop and it performed even better. The blade tapers to a very fine edge which makes it very nice to cut with.
I enjoyed how the knife's edge bit into the wood and made feathersticks easily.
A great test for me to see how a knife cuts is to carve a notch for a bow drill. You have to remove enough wood that if I knife does not cut well, it will be a chore. The hiking buddy cut out the notch easily. Right away I was impressed with how it performed.
I think a small fixed blade like this should be able to perform a few food prep tasks in the kitchen and on trail. I used the hiking buddy for both. It sliced fruit and vegetables easily. I especially liked the fact that I could wash it in the sink with a sponge without worrying about rust or scratching the blade.
In order to really get to know a knife, I like to do a project that is going to take long enough to see how comfortable the knife is with extended use. I decided to make a spoon out of a piece of maple with the hiking buddy. One thing I noticed when I first picked the knife up is that the handle has a more "blocky" feel to it than the custom Fiddleback HB's I have owned. It gives it a more substantial feel in the hand which I like. On the other hand you can feel where the transition from the flat part of the handle to where it curves under as somewhat of a slight "edge". I learned from recently making a knife of my own, that if you can feel a transition like that, it could cause hot spots. Sure enough after extended use I did have a hot spot on my palm and a little one on my pinky. I have a scar on my pinky so that could have also been a part of it. Neither of them were that bad, but I definitely noticed them. This could also be a personal thing to my hands. I will say that in all the custom Fiddlebacks I have owned, I don't ever remember getting a hot spot. Andy's custom knives are know for their comfortable handles and for good reason.
Here is the spoon I made.
Making the spoon I was able to remove a lot of wood very easily.
It comes with a chamfered edge on the spine, which makes it very comfortable for double thumb push cuts.
In these two pictures you can see some slight handle transitions forming a little bit of what I will call an "edge". This "edge" did cause a few minor hot spots after extended work on the spoon.
You can see on my palm a hot spot from where that transition met my palm after working on the spoon. There is also a slight hot spot near the scar on my pinky. They were not dramatic, just noticeable.
Here is a picture of a custom hiking buddy's very smooth scales for comparison.
The mid tech's micarta scales have a texture to them. The texture provides a very nice grip, especially in wet conditions. I used it to clean a rainbow trout and this is where the textured scales and the S35VN steel really shined.
I like a knife with a nice tip for detail work. I wanted to test the tip so I made a small hole through a piece of seasoned California hazelnut. No problem at all for the HB.
I used a green piece of California hazelnut to make a quick figure four trap.
I think one of the most common uses of an edc is to open packages. The HB opened packages like a champ.
My Conclusion:
Overall, I really enjoyed using the mid tech Hiking Buddy. The only problem I had with it was some minor hot spots with extended use. The size of the blade is perfect for a lot of edc and bushcraft type tasks. The shape of the blade is really nice because it comes to a sharp point but also retains enough sweep if you needed to clean some small game. The smaller size definitely makes it a nice "hiking buddy" and I think it could handle mosts tasks you could throw at it while on a trip to the woods. The finish and steel make it really easy to take care of and the textured scales provide an excellent grip. After all the tasks I did with it, it could still cut paper and it was easy to quickly get even sharper on a strop. I think this would be a great knife to throw in a small survival pack, as a gift for friends or family, fishing knife, smaller bushcraft knife, or as a very dependable fixed blade edc that can do about anything. I was sad to send this one on its way. Thanks to Fiddleback Forge for letting me be a part of the fiddleback mid tech Hiking Buddy review pass around.
- Tod
Weight: 3.9oz
Steel: S35VN
My Conclusion:
- Tod
