- Feb 6, 2013
Hoping someone here can shed some light on what I screwed up. I bought a thermocouple, thermocouple sheath and pid controller off ebay a while ago to monitor the temp inside my LP gas forge. I got everything hooked up and installed in the forge and the unit seemed to be functioning fine. I could see the unit registering the correct temp up to about 2000 degrees F then it would display "HH" (which from what I've read is the upper limit of the PID").
Anyhoo...I screwed up and got the rear on the thermocouple too close to the dragons breath off the front of the forge and melted the mini connector. So I ordered a new mini connector and replaced the old one. Now, the unit displays "HH" just past 1300 degrees F and stays there until the thermocouple cools below that temp. I know I didn't modify any settings on the PID and I have verified that the units is set to Fahrenheit...I even switched the setting to Celsius to verify it was going to "HH" at 700 degrees C.
Any idea what I screwed up that my unit won't show temps above 1300 F anymore?
