Paper work with those knives state that they are not suited for utility purposes. The Civilian has a longer hook end than the Matriarch. I would not use the Civilian for utility but I do use the Matriarch. All you have to do is treat it as you would any thin tipped knife.
I went ahead and ordered the Tasman. I am going to go ahead and blame you guys.
If I remember correctly, it is very possible I do not, the same utility work warning that came with the Civilian also came with the Matriarch. It is not really needed as the Matriarch tip is slightly thicker with a shorter hook.I have seen the paperwork on the Civilian and that knife does have a pretty thin tip. Does the Matriarch and Lil' Matriarch also come with this same paperwork? I thought that since the Matriarch tip was thicker and it states utility in the product description that it would not come with the paperwork.
JD
The only real difference is the blade length with the Matriarch 2 being longer, about 1/2", with more hook. Holding them up side by side the cutting edge is almost identical except for the Civilians hook length. Looking at pics of the original Matriarch it had fewer frame screws that were pressed instead of having torx screws.I have two Civilians. An old one with the rubber inserts and the current model. Also a Superhawk PE and a Lil Matriarch. What can I say, I love spydie hawkbills. I'm ordering a Matriarch 2 at present. Never had one of the original Matriarchs. Anyone here know the difference between the old Matriarch and the Matriarch 2?
thanks for this thread. my companion blade is mini dyad, because its great for being around sheeple, post office legal, and it has serrated edge too
