- Sep 29, 2014
I've seen a LOT of knives on this forum and I wanted to get your opinions on Survive! Knives vs X. I own several Busses, LT Wrights and a few others that I have in the rotation along with my GSOs. Here they are:
The GSOs I use on a regular basis:
To kick this off my new 5.1 3v v Busse SJ TAC CG/S Jack:
Head to Head:
5.1 specs:
Steel: 3v
Overall Length: 10.93"
Blade Length: 5.75"
Blade Edge Length: 5.37"
Weight: 11.1 oz
Thickness: .185"
Handles: G10 or Canvas Micarta
Jack specs:
Steel: INFI
Overall Length: 11.25"
Blade Length: 6"
Blade Edge Length: 5.4"
Weight: < 11 oz
Thickness: .187"
Handles: Canvas Micarta
On paper these knives are pretty close. My initial impressions:
The Busse is longer in overall length, blade and cutting length than the 5.1. It has fixed canvas micarta handles and it is just a little bit lighter than the 5.1. Overall it's a very comfortable and easy to use knife. It feels like a big Ratmandu. Initially it didn't cut and carve very well but I had the edge reprofiled to about 20 degrees and now it cuts beautifully. In additional to the 3 lashing points in the handle the Jack also has two tie down points at the pommel and just before the choil. You can use the hole at the pommel for a lanyard. You can also create a paracord hand guard by lashing it to the hole behind the choil and the pommel. Lastly as a chopper I can get a 2 1/2 finger grip on the last contour of the Jack handle, however on the new 5.1 I can only get a 2 finger grip. Chopping this way without using a lanyard is dangerous. I added this to emphasize the differences in the handles and handle length.
The GSO feels beefier even though it's about the same weight, this is probably because it is shorter. The handles have more bolstering and are removable. It has a substantial lanyard hole just below the pommel and if you remove the handles it has 3 lashing holes. The lanyard opening is protected by the scales and the opening is much larger than the Jack. Nonetheless, I could use a lanyard on either knife having to grip the lanyard.
My long term impressions:
I've had the Jack for over 2 years and it has replaced my Ratmandu, not because it's better but I do prefer the longer blade. It's also the only Busse that I use on a regular basis. It sits well in the hand and it has a GREAT choil that is more comfortable to use than my 5.1 or 7/7. If you plan on getting one you'll want to reprofile the blade to make it a better cut and carving knife. And since I've had the blade profile changed it does a great job on wood working. I really like INFI because it very tough and easy to sharpen. I would be very happy with it as a single knife solution for camping or as a large EDC.
I've had my new 5.1 for less than a year but I've I've owned 5.1s for over 3 years. As with all GSOs it cuts, carves, batons and chops very well. It also could be a single knife solution for me for utility, camping and as a large EDC.
Both knives have been used heavily on many different tasks on different types of wood and both have performed well. INFI has a good reputation for a reason and Guy's 3V is becoming a rock star. I don't have a preference in the two steels.
If I had to choose between the two I would choose the new 5.1. It outperforms the Jack in all tasks and not by a huge margin but the beauty is in the details. Even though the two knives are about the same weight the 5.1 feels like it's a more powerful knife than the Jack especially when push cutting, chopping, batoning and long stroke cutting. The 5.1 is also more comfortable in hand after long use because of the bolstering and the contouring of the handles. I thought the same of the old 5.1 and the new 5.1 is even more comfortable. Lastly I like the larger flat pommel of the 5.1 to the window breaker/skull cracker of the Jack.
The Jack does surpass the 5.1 on one respect, the size of the choil. The choil is a little longer and fits my finger better. I tend to get a small cut on the side of my knuckle with my GSOs. At one point I had a callus there. Guy addressed this with the custom 5.1 that I bought from him last year however that knife is 20cv and I prefer 3v. This is the one thing I hope Guy changes when he releases the next batch of 5.1s.
The differences between the two knives are subtle and personal. If I was in the armed services in a combat zone and these knives were being used for defense as well as utility the comparison would be harder. The Jack would be a better weapon. It feels lighter and has a longer reach than the 5.1. You can also secure your hand to the knife with the above mentioned paracord hand guard. But I am not in the military and my use is mostly wood work. For these reasons the 5.1 is my favorite all around knife.
I'd like to compare my LT Wright GNS to the bushcrafter 4.5 when I get it. I'll probably do another head to head with an old 4.1 & Fallkinven F1.
I would love to read how your other knives compare to GSOs and your opinions of both. Or a discussion of why you think differently of my opinions.
Head to Head:
5.1 specs:
Steel: 3v
Blade Length: 5.75"
Weight: 11.1 oz
Thickness: .185"
Jack specs:
Steel: INFI
Blade Length: 6"
Weight: < 11 oz
Thickness: .187"
