- Nov 26, 2001
I do the first one REAL hot, let's say that's almost an anneal.Three is fine, as long as at least the first one is really good and hot. I used to go with the prevailing ideas about low temperatures for blade steels, but now I have been doing enough metallography that I am becoming a greater proponent of using heat to move sutff around, instead of barely kicking things over Ac1 and segregating things worse. If you really want to see cracking- get a heavy carbide laden band down the center of a piece that you failed to break up and then quench just a wee too fast!It will crack along that line every damned time.
Then I do the other two progressively lower and with slooooow cooling.
Then I bring up the blade to non mag very slowly, and, if possible, just the tip and edge, then quench.
