I just did my first heat treat on my first knife and I think I messed it up. I forgot to test the blade with a file after I quenched. I went right to tempering.
It is New Jersey Steel Baron 1084. I normalized by bringing to a nice even orange glow where a magnet would not stick, then I let it cool until it returned to the normal gray color. There was still some heat in the blade. I could feel the heat on the back of my hand from about a inch away but it was just a warm heat. Back into the forge it went when it reached this point. This was done three times.
For the quench I brought it to the same even orange glow where a magnet would not stick. At the same time I had another piece of steel in there getting the same temp. I used that to heat up a jar of peanut oil where it was nice and hot. Not too hot though, I could still stick my finger in it. About the time that was done the blade was just coming to the even orange glow and i quenched it in the oil. I held it in there till there was no more bubbles coming off and it had cooled significantly. When I pulled it out it was almost warm enough to hold but not quiet. I wiped as much of the black stuff off the blade as i could get off with a towel and went to tempering.
For the tempering I put it in my wifes oven at 375 for 2 hours. When it was done I pulled it out and let it cool to room temp. I then pout it back in at 425 for 2 hours. After done I pulled it out and let it sit overnight. This morning I tested with the file and found that it is leaving scratch marks. It's my understanding the file should skate across the blade and not leave scratches. Should I get all the black stuff off (there isn't that much really) and try the file again or is part of my process wrong?
PS.
If I did mess up the process can I do a second heat treat on this steel or does the knife go into the trash?
PS.
