- Feb 18, 2016
How long of a temper? I just did a smaller .12 blade last night at 300 for 90 min let it cool to room temp then again at 400 for 90 min. Just a hidden tang hunter/utility
I had been using our kitchen oven to temper my 15n20 and it gave pretty consistent temperatures and good results. I wanted to move everything to the shop, so, I bought a toaster oven and started using it. The problem I found with that is that the temperature fluctuates 20 degrees in either direction. How much could I be losing on the hardness scale with that type of temperature fluctuation? I am currently setting the toaster oven at 335-340* f.
The problem with toaster ovens is there temp control is a simple heat sensitive contacts. And I'm guessing it takes a swing of 20deg on both ends to trigger the on and off. If I had to use a toser oven I would wire it with a pid and SSR and remove the cheep contacts.
Hope I'm not derailing, if so, let me know and I'll start a new thread.
Thanks,
As a rough reference, 25f is about one Rc point in most simple steels.
David, this is a three year old discussion.
To answer your question, 15N20 should be HTed in a HT oven. The soak time is needed, and exact temperature is pretty critical.
I use 1" thick aluminum quench plates mounted in a quick release vise to quench AEB-L. When I read the posts above by Stacy and JT in the summer, I started using this setup for straightening carbon steel blades after oil quenching as well. I mostly use AEB-L and have only used it on three kitchen knives so far, but they all came out perfectly straight. Prior to that, I always had warps, so I am going to keep using this method.Don't mean to resurrect an old thread but lots of good information here. One question I do have is in regards to the quench plates. Is there any particular size/thickness I should look at? I will be mostly doing kitchen cutlery in 15n20. I
Thanks.
Thanks for the information, I'm a hobbyist as well doing mostly carbon blades. I just recently retired and would like to try AEB-L and some stainless in the future. I was thinking the one inch plates and what you said makes sense, thanks.I use 1" thick aluminum quench plates mounted in a quick release vise to quench AEB-L. When I read the posts above by Stacy and JT in the summer, I started using this setup for straightening carbon steel blades after oil quenching as well. I mostly use AEB-L and have only used it on three kitchen knives so far, but they all came out perfectly straight. Prior to that, I always had warps, so I am going to keep using this method.
If you think you might want to heat treat stainless at some point, I would recommend aluminum plates, the thicker the better. One inch thick has worked well for me, but I am just a hobbyist. For straightening after oil or water quenching, I bet you could get away with thinner material, or even angle iron as long as it is straight enough.
While I haven't tried it yet, a respected knifemaker and member of our local knifemaking club (the 5160 Club in Eugene, OR) claims that he skips the Parks 50 and goes straight to aluminum quench plates for his thinner 15N20 kitchen knives. And I believe him after ruining more than a couple drill bits trying to drill through tangs after forging out a damascus blade where I use 1080/15N20. The drill bit would start the hole, then hit hard steel which I was told was the 15N20, which can air harden in thinner sections.
Thanks JT, I'd love to see what you get.I will do another test when I’m doing 15n20 again to get an actual number for plate quenched.
