I am a relatively new knife maker however I have been using ATS 34 for over a year and made a number of fixed blade knifes so far. I have used the same recipe for my heat treat since the start. 1950 for 30 min pull out quench between 2 inch aluminum plates, then temper at 400 twice two hours each time, with a air cool down in between. This has consistently produced a 59-61 hardness for me. However I recently got a new batch of steel and used that same recipe but after the temper the blades were testing at 65 (yes I cleaned them off light sanding before testing). I did not test these three knives after they came out of heat treat, but I had two more in the oven, so after they quenched and cooled I tested them before temper and they tested at 65. I put them all in at 450 for two more hours and nothing, they all came back at 65 again....
So I put one knife in at 700 for 1.5 hours and it dropped 2 points to a 63. My questions...
1) is it ok to use a high temper on these fixed blade hunting knives? I have read that it takes some of the toughness out of the knives but how much? I am not making world class collectors, my customers are local people that use these knives daily in many cases.
2) Should I go up to 800 or 900? I really want to get these guys down to at least 61. How high is to high? What is the best way to get them down?
3) Next time I put a batch in to heat treat should I run them at 1900, instead of 1950? Or should I hold them at temp for less time so they don't come out at a 65?
4) I got my steel from a real reputable place (not sure If I should name them) but I have used them for sometime and many other knife makers do as well. But...Is there a possibility I don't have ATS34 here? Is there anyway to tell?
Any kind advise would be appreciated.
