http://www.evenheat-kiln.com/techni...tainless-Plus Damascus Heat Treat Procedure:+
that one's pretty accurate.
It's all science - but choosing the science is something of an art.
Rob!
I disagree. Evenheat describes ATS34 and 154CM as requiring oil quenching. Rob!
Got one for W2?
Kevin told me that a while back and he said that you can get some pretty wild figure if you etch even a "fully hardened" large blade. I noticed that when I polished out the bowie that I sold to Colin KC, it had faint lines that made it looke like it had been edge quenched. I used heated Tough Quench on that one, whihch I guess is a "slow" fast oil, if that makes any senseSince there has been a bit of legal wrangling going on in these forums I thought I would post a note here:
While I am sure that the ASM is very glad that their data book is used as a standard reference for knife makers, I doubt they are happy that the pages are scanned and published on this forum (and thus on the web). They get a high price for their book, not because they are greedy, but because it takes a lot of research and work to assemble and continually update a book of this scope. We should be forthright enough to support their efforts by either
1) Buying a copy
2) Borrowing a copy from a friend or Library for our own research.
3) Asking a friendly knifemaker the temps/times from the book (a regular item on this forum).
We should NOT be copying whole pages for any more than personal use, and should not distribute those copies. Besides being a copyright infringement, it is not in our best interests to slap the face of those who are helping up. (BTW, the copyright use permission under "educational use" specifically does not allow publication in any form)
I say give up one beer (or Starbuck's coffee) a week and you can buy yourself a copy by next Christmas.
The other plus is that having a $200+ book will encourage you to read it. There is a lot more in those books than just charts. You will learn some metallurgy reading one. Also, looking up the data for yourself, and reading the WHY of it will help you learn how to figure your own HT specs, not just ask blindly.
Stacy
jdm61
W-2 is a shallow hardening steel. Those charts show that a casting or stamping size piece will surface harden and have a soft core (which is usually desirable in that situation). For the thickness of a knife blade, the hardening will be fully hardened as long as the steel is brought below 900F in less than 1-2 seconds (quite easy in water or brine, and attainable with a fast oil). If you are making a BIG chopper with a 1/4" spine, it is possible that the center of the spine area will be a tougher and less hard structure.The edge area would be fully hardened at least 75% of the way toward the spine. That would be a plus in my book.
Stacy
3/16's fully hardened gets me where I want to beWhen I post charts or graphs, if folks look closely they are not expact copies of any published version. I heavily rework or recreat my own in Photoshop inorder to be entirely free of the whole copywrite thing, but that is also why I am not very prolific in posting such things, it takes time for me to create them. That is also a very large part of why I got involved in metallography, I was always in the need of micrographs that were not the property of somebody else.
The size vs. depth of hardening issue has been addressed here and it is a very valid point. It is often pointed out that we spend too much time with TTT curves based on equilibrium conditions in determining what happens in quenching, while Continous Cooling Curves deal specifically with these circumstances. However, TTT curves are generated using samples of smaller cross section while the C-T curves are based more upon the standards of the Jominy end quench methods, which involve round cross sections of 1" diameters. Neither diagrams are dead on for what we do, but I have always found the TTT to be more useful than trying to extrapolate the C-T curves.
In water W-2 should be able to through harden, but in light oils the through hardening will be limited to increasingly thinner cross sections. I would expect around 3/16" to be around the limit to avoid fine pearlite. To get a better grasp of these concepts I would once again refer back to the Jominy type test for examples of shallow vs. deep hardening of steel.
