I did HT on S30V with stainless foil and AL plates. Quenched from 1960F. Never had problem before. This time, the foil welded to the blade. Had to grind it off. Not a big problem, but not sure why it happened. Tried same process with another blade, but this time rubbed soapstone on blade before sealing in foil. Same steel, same foil, same temp. but did not weld. Blade came out very clean. Foil is high temp stuff, supposedly good for over 2000. This was the first time this happened, after treating a number of blades with same process. Any thoughts or similar experiences?
Chip Kunkle
Chip Kunkle
