Assuming you have 220VAC available, you want to build for 220VAC.
You can use either a single 220VAC element, two 220VAC elements in parallel, or two 110V elements in series.
If you are following the Andy Gascoigne plans that have been in various places on the web for many years, Andy used two of the 110V elements in series to run on 220V. BCS, the supplier of his elements, subsequently started selling 220V elements as well and this has caused some builders some confusion. The 220V element is twice as long as the 110V.
Personally, I always use two 110V elements connected in series: one element in each of the side walls. Using two 220V elements connected in parallel could work, but would need twice as much groove length to accommodate the longer elements. If I have the wall area available for longer elements, I use it to go for thicker element wire to give longer element life.
