- Jan 18, 2004
This is some O1, the blade is a rather large Bowie that I'm making. While finishing at about 400 grit, I started noticing the "blotchy" pattern. If I slowly run my fingernaeil across these areas, I can feel that it's rougher, maybe "micro-pitted" if you will. I used Brownells PBC at about 550 F and got a nice dark coverage, then ran the temp up to 1550, with the blade in the furnace (Lindberg), soaked 30 min, edge quenched in Brownells super, I did not heat the oil, but rather followed the instructions on the can. The blotchy pattern was in the oil. Then tempered at 400 for one hour, twice. I'be backed down to 220 grit, but it hasn't taken the problem out, will try aggressive 120 today. The other side of the blade is beautiful. Any ideas, any solutions?
