- Nov 29, 2012
I am using 1084 steel. I am using a paint can forge with a Mapp gas torch. I did some blades this weekend and one of them was a little long to fit all the way in. I did the blade first and once it attained the right color I quenched it in heated canola oil. After it cooled some I put it back in the forge to do the rest. After the same procedure I put the blades in the oven for 2 425 degree temper cycles including cooling under tap water between and after. The blade came out with about a one inch section on the blade near the ricasso that is blue. The rest has a straw type color. My question is do I need to reheat treat this blade or will it work like this?
