Don't want to upstage TTTis, but you must remove the titaniun stud, gets too hot in there.
I remove the stud on all of mine to reprofile the edge, then reinstall the same stud, not difficult.
It's 2015, and the heat treat thing is still going?
Summary & Conclusion
Hardness is an important factor when choosing a material for a special purpose. Fifteen specimens of materials were chosen for hardness testing in this lab. The samples were designed on an approximate comparison of hardness scales chart to show the relationship between the hardness values of the samples. A table of comparisons was developed to show the hardness values of the samples on the different scales.
In this lab, it was found that Rockwell B is being use for soft steels and nonferrous metals. On the other hand, Rockwell C can be applied to hardened metals. The shore scleroscope measures hardness in terms of the elasticity of the material. Shore D measures the penetration of a steel penetrator with a static spring load applied
The hardest material sampled was Bearing Race with a hardness rating of 60.5 Rc. The softest material tested was Polyvinylcloride (PVC) with a hardness rating of 76 Sd.
Oh. Thanks for the explanation. [emoji57]Nothing wrong with wanting to make something perform better. The Rc scale is not like a 1-10 scale where each number is just one step up. It is more like the Richter magnitude scale (not identical though) that is used for earthquakes. There is a difference between 59 and 61.
http://lennon.csufresno.edu/~mhk03/hardness_1.htm
This is interesting. Is the thumb stud removed prior to heat treat? If so, does Paul Bos provide the service? If not, what does the thumb stud look like after? I'm assuming the blue changes color.
