The purpose of the 5160 blade I'm using here is just to familiarize myself with the HT process. I've read before that after doing an edge quench and the blade cools down enough, one is supposed to wait 12-24 hours before performing the next quench.
1) Does anyone know the purpose of this?
I know in annealing you want to cool down the blade as slowly as possible... and in other steels like the 10xx series you want to temper right after the quench.
I tried a second quench today and left the blade in the oil for about an hour. Went out and checked on the blade, the oil felt a little warm. Checked an hour later and it didn't really change much. The oil is in a steel pan outdoors in AZ, so it probably wouldn't have cooled down much more because of the ambient temp. So I basically did a couple more cycles just to see what happens... edge quench for 10 seconds or so, then let the blade rest in oil for 1 hr. So far, I'm on #4. Again, the purpose of doing this is to test my ability to hold the blade well with tongs, check for nonmagnetic, etc.
2) I'm using ambient temp oil, probably 80-90 degrees is my guess. Is the purpose behind warming up the oil to not shock the steel as much, like with water... possibly causing it to fracture?
3) I read that the most critical time for the quench is the first second or so, when it's going from 1550/nonmagnetic to sub 900 or so estimated. Has anyone tried a really quick swipe in water for say 1 sec and then gone over to the oil so it's not as abrupt a total change as with only water? (i.e. a two quench tank setup)
4) Finally, regarding the original question... would there be any benefit to say, letting the freshly quenched blade sit in the oil for a couple minutes, then transferring over to water (warm or cool) to hasten the cooling process? Or is the slooow cooling what is important? if that's the case, why not use vermiculite instead of oil?
Thanks in advance folks... any insight is helpful!
cheers,
erik
cheers,
erik
