Heat Treat Recipe
Hi Everyone,
I'm getting ready to heat treat a tomahawk I forged from a 24 oz ball peen hammer. Does anyone have a heat treat recipe to normalize, quench, and temper it?
I read somewhere that a lot of ball peens are made from 4140 steel, but can't be sure?
Any advice is greatly appreciated .
Thanks,
Bobby
You have a 'mystery steel'. It's all a guess and unless you have a very good quality hammer it's most likely NOT 4140.
Hey Mete,
Thanks for your reply... I just found this post fro 3 years ago.
Stacey provided me with the information
I make hawks from HF ball peen hammers. Get the five piece, 12oz. to 32oz. set when on sale, and make small, medium, and large hawks. The steel is something around .40-.50% carbon and is just right for hawks.
They don't take long to forge out, and are good projects for the crowd to watch take shape at demos.
Put the hammer head in the forge for a minute, and the head will come off the handle easily with one whack from the forging hammer. Save the larger wooden handles to make hawk handles for the smaller hawks. The surface char will grind off.
You will need a pair of large bolt tongs and a pair of rivet tongs.
Do forging and drawing at high red to orange heat, and re-heat when it drops to low red.
Using a 16oz. to 20oz. head:
Start by drawing the ball straight out into a 4" long tapered spike. Hold the peen head in the bolt tongs.
I like the spike sides flat and the top and bottom rounded, but the shape is up to you. Don't curve or finish the spike yet.
Use the spike to hold in the rivet tongs, and start flattening the peen. Once it is flattened a bit, start "pushing" the metal toward the outer edges from the eye direction.
At this point, drift the eye with a hawk drift. Once drifted to size, I have a 2" piece of mild steel that I have shaped the same as the drift end. It is the size that I like my handles. I drive this in the eye, and leave it there. This prevents the eye from getting too distorted while finishing the hawk head.
Continue to draw out the hawk blade. Once it is out about 1.5-2" inches, start dropping the beard downward. Shape a little more until it is getting to look a bit like a hawk blade.
Continue drawing the blade until it is shaped and done. Leave the edge 1/8" thick.
Finish shaping the spike and curve it down as desired.
Once all is looking right, give the metal plug in the eye a whack and knock it out of the hole. Clean the hawk up on the grinder, and/or with files until shaped and smooth. About 220 grit is fine.
Heat the hawk in the forge and quench the blade edge in oil up to about 1" from the eye. Let cool in the oil for a minute.
Heat the spike only, and quench to about 1" from the eye. After about 10 seconds, quench the rest of the head.
Temper at 450-475°F.
Make a handle from some nice curly maple ( or buy one pre-shaped from a supplier), and finish it to accentuate the curl.
The edge can be made sharp and at 25° for a cutting/fighting hawk, or at 30-35° for a throwing hawk.
Most of the time I am using the slack tub of dirty water. It is usually warm from cooling the tongs and such, so I would guess that 100F is about the temp. Sometimes I use the oil quench tank. I can't say one is better than the other. I have had a hawk or two crack in the water, so the oil is safer.
Stacey,
I copied your technique from a thread back in 2011. I haven't really needed the recipe till now though.
It is quite difficult for me to forge these 24 oz hawks, as I am not properly set up to do so. As you probably already know, hammering out a big old ball peen takes some effort. And drifting the eye is challenging especially when you don't have a nice drift post set up.
This latest hawk was drifted by using a 2" piece of mechanical tubing over my hardy hole. It took quite a number of heats to accomplish.
I've gotta get better tongs more suited for the task as well.
Thanks for all your help,
Bobby
