- Oct 19, 2010
I'm looking for some pictures for comparison of a post-heat treated piece of S7 Steel.
Using Crucible specs for heat treat I want to see what the steel comes out of the kiln looking like..
Something heat treated + - of the following:
1350 soak for 2 hours
1725 soak for 25-45 min
air cool
What I want to see is some kind of typical result as I have not been able to find any pictures of post-heat treat steel.
I'm not using foil or coating of any kind...
Heat treat naked steel
Air cool naked steel
Temper naked steel.
Anyone help me out with some pictures of what this looks like?
What I'm experiencing is a layer of black material that is uniform over the entire surface of the metal I've heat-treated. As the metal cools this material literally pops off and crumbles when touched leaving a dark smooth finish on the S7 steel.
I think what I'm dealing with is either oxidization or decarburization or just normal S7 heat treat scale?
The material I'm using is 12" x 2" x .25" thick.
The finished product is both strong, resilient and durable and has held up to all the tests I've been able to think up and perform on it. I'd just like to know if this is common or something unique to what I'm doing.
RC is between 55-60 using a numbered file set and the scratch test. Its closer to 60 than 55 as the file does not want to bite much, but it does a little. The 65 bites right in.
Thanks!
- Hal Zucati
air cool
Temper naked steel.
Thanks!
- Hal Zucati
