Hey Peter,
I used to boil water and borax and dip my blades in it and let dry before heat treating, but found it a lot easier and better to leave quite a bit over sized, then heat treat, then grind to finished shape with a new 50 grit belt and then go straight to a new 400 grit, just like steve johnson does it, I stop there and go to hand sanding because I'm doing mostly flat grinds off a platen, but if your doing hollow grinds off a softer wheel, he says you can take them to a mirror finish with just a couple of cork belts and the buffer. His tutorial is on CKD, several say it works great.
Bill
