1084 is the easiest steel out of them all to heat treat well. All you need to do is get it to 1500F and quench in a medium speed oil. 130F canola works very well. To get it to 1500F without having a digital readout telling you what temp it is, use the magnet. Heat the steel up. Once it turns a deep red color, check the magnet against it. If the magnet still sticks....it needs more heat. The magnet will stop sticking at around 1414F, but we still need another 85 degrees hotter. So you need to notice the color when the magnet stops sticking, then go a shade or two more, in order to reach 1500F. Also, salt melts at 1475F I think. But the magnet trick works very well. Just remember, once the magnet stops sticking...you still need another 85 degrees or so before it is hot enough. No need to soak with 1084. Once it is at 1500F, quench.
