I’m not doubting what your saying at all the only thing I’m wondering is how close to the full potential of the 1095 did I get with ATF vs parks? If it’s super close then I don’t see a point in buying parks 50. If there is still a bit of room left for improvement then yes I’ll buy some more expensive parks lol. I have annealed a flat file then re hardend it with atf just to see if I could get the same hardness level. I got the file back to as hard or harder than what it previously was? That’s why I’m wondering if the parks #50 is worth it ? Yeah I get the whole it’s not to safe stuff but then again I’m sure pumping gas is toxic to an extent an has carcinogenic effects same as the batteries being made for electronic devices and all of the electronic devices you have around you right now. So with that being said I’m not to worried about the toxicity with ATF as heat treat oil it’s not like I’m trying to inhale every cloud vapor .
With an inferior quenchent it won't cool the steel fast enough while submerged.
 1095 is very demanding and needs a fast quench otherwise the carbon you're trying to trap to harden the blade will escape and make softer structures that won't be removed with cold treatment, tempering etc.
Parks 50 gives you the speed you need without going so fast you risk extreme warps, cracking and breaking. So, it pays for itself in the end.
The problem with using improper quenchents with a steel like 1095 is that you'll have softer patches (pearlite) hidden in your hard microstructure that can't be detected with a file because the file just rides over it.
This translates to an edge that will not be as strong and stable as it could be.
Translation: won't hold an edge good
I know personally from making mistakes and not having the right equipment when I got started.
Like yourself, I didn't understand all the "mumbo jumbo" when I was new and thought it was overblown.
Well, its not.
I highly recommend investing in the parks 50.
You'll also enjoy better temperature control with a good furnace like an Evenheat when you decide to invest in that. Using the right austenitizing temperature is perhaps the greatest factor for performance in HT so its very important.
It only gets better the more you invest in it.
You can run a comparison with a knife you send out to a heat treatment service and see if you see a difference for yourself.
Have Fun.
