sotake that for what it's worth and double check the temp with a multimeter...The melting point of 1475F is for very pure sodium chloride. Any time a compound has impurities present, the melting point is lowered.
Usually, common table salt isn't pure sodium chloride, but is often iodized and/or has other constituents added to make it flow properly in a shaker.
Any adulterants like these will lower the melting point. Just how much is difficult to predict offhand.
Thus, if one wants to use salt melting temperature as an accurate indicator, one needs chemically pure sodium chloride to get the best accuracy.
Ditch the motor oil for a gallon of mineral oil/canola oil/ATF any of these is better than motor oil. however by the time you pay for these, you can add 15-20 dollars and buy a gallon of proper fast quench oil from McMaster-Carr. DO THIS! your quench medium is THEE MOST IMPORTANT ITEM in knife making other than the steel itself!)
Jason
