- Oct 2, 2006
I really don't understand the hangup on HRC. It's only one value and most useful to tell you if you're heat treating the steel correctly. There have been many many knives made for many many years that would RC in the low 50's and were still thought to be "good". CPM3V in the low 50's would probably be "better" than many of those old knives. What are you getting with the extra 1-3 points of hardness?
You're approaching file hardness at 63. Why would one strive to get "better than average steel" results with a steel that can perform exceptionally just to get a couple rockwell points?
Maybe you're onto something, but the only real way to find out would be to do several at different hardnesses and put together a standardized testing method to see if full hard 3V performs better than the others in your application. If not, then you'll never really know if you got a better knife, or just a harder one.
The hardness allows the knife to hold thinner edges. Each point in hardness adds 20-30% better edge retention and allows 2° degrees more acute edge bevel which translates to a very significant difference in actual use. These are my own estimated numbers based on actual experience. 63 rc is not very hard, it's a compromise that actually favors toughness as far as small knives are concerned.
Again, the difference in just 1 point difference in hardness is very noticeable if you thin down the edge. If you're using greater than 30° degree bevel, you might not ever notice the difference.
I'm interested in hearing other peoples' experience in this though.
