Flexibility isn't determined by HT. It's determined by geometry.
ETA: grind your knife, then flex it side to side, like you would when using it. If it has the proper geometry it will snap back straight. If it stays bent, you need to change your geometry.
The point that it bent, would be the point it at which it broke, if you had done the HT.
I have heard something like this many times yet still don't get it.
If you have a thin knife made of 52100 have it hardened without tempering with as quenched hardness of 66HRC and another one that has been triple tempered to 59HRC. Do you really think these who knife going to flex the same? I doubt the first knife gonna break as soon as you try to flex it.
So saying flexibility isn't determined by HT doesn't sound make sense for me.
I have the greatest respect for you bluntcut and your expertise in cutlery steels, but I just can’t read that explanation in that graph. I can’t help but think that you may be misinterpreting what they are trying to show. I’ll also say that it isn’t real obvious to me either, but I will have a go:
@54Rc – fractured after it had bent by a total of ~9mm plus a smidge, at some applied load which is unspecified but which calculates back in a simplistic way to an ultimate stress of 5000MPa in the inner and outermost imaginary fibres. Of that 9mm, 6.5mm took place after yield, in the plastic zone. So, if you had stopped bending just before it broke, it would have sprung back about 2.5mm leaving you with a 6.5mm permanent bend. It first yielded, or started to take a set at a force or load equating to 2500MPa, so about half the load that it broke at.
@58Rc – ditto but final bend before fracture of about 7mm (equating to 5600MPa in the outermost fibres), of which slightly more than 4mm was permanent. It first yielded at a load equating to 3200MPa or almost 30% more than that which it took to leave the 54Rc sample with a (tiny) bend but then broke at only 12% higher force.
@62Rc – same again but a final deflection of only 5mm (maybe 5700MPa) and only 2mm of which was permanent. This one didn’t start to take a set until a load which equated to 4000MPa or 60% higher than the 54Rc sample and 25% higher than the 58Rc one, but it broke at only a little if any higher force than the 58Rc one.
Everyone saying that the harder material in the same geometry takes the same load to bend the same amount is totally correct up to the point at which the permanent set starts. For these particular samples around 2.5 to 3mm. Up to that time, they would be indistinguishable. After that point, the softer one will bend further for a given load, thus seeming less stiff and most people will realise they have pushed too hard, like when you strip a thread, and it will then stay somewhat bent whereas the harder one will continue to push back just as stiffly as it did and end up putting up with a higher load even though it will, in this case, actually finally break with less total deflection. But by that time you will have been able to flex the 62Rc sample about 60% further than the 54Rc one went before it was permanently bent. I guess it may depend on your criteria for failure as to which you prefer.
That was your first mistake.I have the greatest respect for you bluntcut and your expertise in cutlery steels
At some point once discussion has shown to not be effective, charlatan trolls should simply be pointed out and ignored. I don't feed trolls.A tactical metallurgy punch would be more effective...![]()
HT to harden steel for more strength. Please explain why we want this 'strength' when strength is not useful(or applicable) in conjunction with elasticity of blade & edge? Nifty sure, car springs are made out of hardened, not annealed steels or iron.
As noted above, annealed steel takes a set much quicker than hardened steel. As you go harder, the steel breaks, rather than reaching its elastic limits. In the lower hardness ranges, steel will take a set when bent, before breaking. The amount of force needed to flex the steel doesn’t change, that’s down to geometry. The point it takes a set, or breaks completely changes as different hardness levels. This is one of the most confused principles when working with steel.
