Sam, Your baffled oven will work, but needs a lot of technical changes to be efficient for heat treating swords.If you want a heat treating oven for long blades, you need a different setup. First, for a more even and efficient heat, use 2" of wool. Second, if you want to avoid hot spots from the flame, and the problems with oxidizing/reducing flames, just isolate the blade from the flame entirely. The way this is done easiest is to make a long tunnel forge with a five inch round front and rear opening. Have one burner for each foot of body length,with the end ports 6" from each end (for a 36" oven that would be at 6",18", and 30"). Place a schedule 80 piece of stainless (312/316) pipe through the forge,with about two inches sticking out each end. Weld two 1" spacers at 4 and 8 o'clock position in the openings on the ends to support the pipe in the center of the doors.This will allow the exhaust gasses to vent.
Make a plug for the pipe ends from soft firebrick. Plug the back and mortar it in with satanite. Put your thermocouple probe through this plug, sticking down the tube. Use the longest practical probe. A 1/4" by 16" monel probe will work great. Use the front plug as a stop to keep oxygen out of the pipe. This pipe is called a muffle. The temperature inside the pipe can be very evenly controlled by allowing the forge chamber to come up to heat and stabilize.After about 15 minutes, the muffle should be stable at the exact temperature the controller is set at (using a PID and a solenoid valve to regulate the gas supply). If you are not using a controller, you can adjust the flame with a needle valve to get a pretty close temperature control.
Wrap a single sheet of notebook paper around the blade, and pace the blade in the muffle, putting the plug on quickly. The burning paper will eliminate all the extra oxygen.
Stacy
PS: This same forge can be used without the muffle to forge long blades.
