I am not totally new to heat treating metals, but I don't have a forge or an oven. I do have oxy-acetylene for heat and a recently-purchased BBQ grill which I have heated to a temp of 700+°F according to its built-in thermometer. I know this equipment is inferior to the forge and/or oven, but it is what I have to work with.
I have made 2 blades, one from a Nicholson file, and the other from a non-laminated chainsaw bar. I annealed them both to a working hardness by heating and allowing them to cool slowly, and have finished shaping them; now I am ready to re-harden and temper them. I have been successful in the past (making small chisels from hacksaw blades, etc) by heating to cherry red, quenching, polishing, then tempering using the color-change of the metal as a guide to when the correct temper is reached, then quenching again. I plan to do this with these blades, BUT I have been warned that whether to quench in oil or water must be determined first.
Which medium should I use for quenching each material? Should I depend on the BBQ grill's thermometer when tempering, or would it be better to use the color-change method?
Since I am not using first-class materials or methods, I am not expecting a first-class blade, but I would like it to take an edge without rolling, and I don't want to crystalize the edge during hardening or tempering!
Answers to these questions and any additional advice will be appreciated; thanks in advance.
