Look at the stickies on the top of the Shop Talk page. there is a lot of good info on HT in them.
1084 is the eutectiod steel, and has the simplest HT of all steels. You just have to heat it to around 1450-1500F and then quench in canola oil to get a good blade. After the quench, you have to temper it in the kitchen oven at 400-450F for two hours, twice. The heat source can be a torch , a forge, or a HT oven. 1084 is pretty bullet-proof as far as HT goes. Use a magnet to get an idea of how hot the steel is.
Here is a prior post I made on the same question:
Here is a basic HT regimen for 1084:
1084 HT:
refine grain and normalize -
heat to 1500F ( medium red) and air cool to black, then quench to cool
heat to 1350F ( just non-magnetic) and air cool to black, then quench to cool
heat to 1200F ( still magnetic) and air cool to black, quench to cool
Straighten any warp or twist
Austenitize-
heat to 1500F ( just a bit redder than non-magnetic) and hold long enough to allow the blade to be evenly heated.
Quench in a fast quenchant (or as fast as you have, canola will work for all but biggest blades)
Check for warp after holding in the quench oil for 5-8 seconds. Straighten immediately. Stop after about 20-30 seconds, as the blade will be too cool and may break.
Temper immediately at 450F for two hours, twice. Quench in water to cool between temper cycles.
( If there is any warp after the blade cools, it can usually be straightened while at tempering temperature. Let it heat for 30 minutes before any straightening.)
