Hey everyone, i am new to this forum.... i have asked this question on another forum and also did some research but cant find a good solution. So all the blades i have done up to this point have been 1084 heat treated in a propane forge. So i ordered a even heat oven last week. And i have access to liquid nitrogen for cryo. So i want to start with stainless and just received a order of 440c. Anyway i have the 1 in thick aluminum plates but i also have a big bucket of parks 50 quenching oil. a couple of people that have been given me good advice so far say that any steel (including 440c) that can be heat treated in air or with plates can also be done in oil and some come out better in oil. So as soon as the oven comes (i already have 2 knives profiled) i want to plate quench one and oil quench the other followed by the cryo and tempering to see wich one comes out better or if there is no noticeable difference. problem is if you wrap the knives in the foil packet how do you get it out of the packet quick enough to get it too the oil? the people that suggested the oil have a argon intake into there oven so the foil packet isnt a problem. But i assume that some one some where has come up with a tool, technique, or method to get the packet off quick, The best idea i have hear is a razor blade attached to a steel rod so when you open the oven you can reach in and cut the packet open before it leaves the oven. i am not sure how good that would work and even then once you open the door does it still loose its heat quick or is there enough residual heat in there to keep it good and hot for a minute or 2 while you cut and open the packet whiles its still in the oven......i would love to hear ANY ideas on this thanks guys!
