db said:
ow much of a temp difference makes a difference 10 degrees, 5 degrees, 1 degree at the temps used for heat treating?
Clark gives some information specific to 52100 on his webpage on salt pots, you can run a simple linear interpolation to see the effect per degree and then compare the effect the %carbon makes to hardness by looking at the graph kell_aa posted awhile ago to see the kind of effect you can expect per degree shift on hardness. However note that steel varies as well. Look at the carbon and chromium variances for 440C and think about a blade from one end to the other. When you run really small batches you can adjust for this by altering the tempering, Wilson does this for example as he HRC tests each blade. You can't expect production compaines to do the same and thus they will have more variance.
http://www.mvforge.com/salt pot info.html
The custom makers who are really serious about performance will individually test knives from each batch of steel (quenching media, etc.) to confirm they are all on target. However it isn't that uncommon to have production companies comment on problems with batches reaching the public both in terms of geometry and the steel. If you want specific information on ovens just contact a manufacturer and ask for specific details. Realize though this is only one small factor, you also have issues like the time at temperature, effect of preheating, how they are removed, how long before tempering, etc. .
Im not even going to ask about salt baths, I dont even know if they are used ....
Several custom makers are using them, I have not heard of a production company doing so yet. They do solve many of the temperature problems with ovens. One of the major problems with heat treating aside from austenization is the tempering and they addess that as well. Otherwise lack of agitation is usually an issue, especially in air cooling. Just think about a blade surrounded by numerous other blades compared to ones on the outside which only have blades on one side of them. Now think about the temperature gradient across that essentially really coarse crystal structure.
No I didn't call Bos, the cost of a long distance call would be the price of a tool steel textbook and generally I don't ask serious questions about performance/steel on the phone from maker/manufacturers because it would be all private information and not repeatable thus useless from an academic point of view. In private since there is nothing to insure responsiblity people tend to say things they never would in public. I have heard lots of things about knives/makers in such conversations which are staggering if true, but they are just rumors, nothing more.
Swordforums is probably the best user interactive blade specific heat treating/materials resource now. Cashen specifically has a crazy amount of resources dedicated to actually understanding steel. He even bough an impact machine awhile back. He is also one of the few makers who will publically comment about the hype about testing / steels / heat treating. If you have not done so, scan through the Metallurgy sub-forum there, specifically for example look at the comments regarding the effects of forging, high cycle normalizing, multiple quenching, etc. . The list goes on, he has also wrote several very nice articles about the myths of modern blade making which are worth reading.
-Cliff
