Part of it depends on how you do your HT. When I do a blade of something like 5160 or 1095, that is going to be taken to around 1500,, I get it to around a good 220 grit and HT then I grind of the HT crud and finish it off. I have been doing D2 lately and I finish each batch of knives a little better before HT because I wrap them in SS foil before I take them to 1850. They come out with no scrud and an interesting grey. Then I can hand sand or whatever from where I left off. If I wrapped the lower heat blades I would get the same results, Problem is they need to quench faster and the foil would solw that down to much and getting them out of the foil for quench would be too slow also.
