I am in the process of making a few pair of O1 file guides (1/2" x 5/8" O1 stock, stainless screws and pins). I have the sets nearly complete and was wondering if I could do the heat treat when each pair is fully assembled and bolted together. If I did this I would not peen in the pins, but instead keep them loose then after the heat treat swap out the screws and use new pins.
I was thinking this may help to 1) keep everything straight and 2) keep scale off the inside surfaces. I would appreciate any input you may have....is it a bad idea to heat treat the assembed guide for some reason?
Thanks
Thanks
