Hi, I'm in the process of making my own HT oven. There's a lot of good information material online and I think I've got everything sorted.
It's a 6x6x15 inch oven at 3100W (240v@13A)with a 14 gage kanthal A1 wire coiled up to 12mm diameter. The power density is roughly at 1.13/cm2 and surface load on the element coming up to 2.3W/cm2.
I just figured out that my line can supply up to 20A at 230-240V and I would like to increase the power as that means heating up is much faster. But I read somewhere that if your oven is too powerful, the PID controller has a hard time at stabilizing and will overshoot.
So my question is, if I have the scope to increase the power by using a thicker element and changing other parameters ofcourse; is it worth it? Am I missing something here?
I plan on using the Rex c-100 controller as it is easily available and cheap. Would probably replace it down the line.
Also I've seen in some places that they add two SSRs. Why would that be? To me it seems like potentially an additional point of failure. But maybe I'm missing something here.
Any advice would be appreciated. Thanks.
