So far, every one of my attempts to HT has failed, all blades and bits of scrap have failed the file test. I've been working with steel from leaf springs, mower blades, concrete punches, old chisels and files.
Okay, I've read the sticky on the principles of quenching, and everything else I've been able to find on here about how this is done, and I think I've followed it pretty accurately. My process is as follows:
After forging and stock removal, I anneal the blade in ashes. It takes a few hours to get cool. I clean up the blade and heat it to the point that it becomes non magnetic, then just a bit more, then quench tip down in warm oil. I take it out of the oil when it's cooled enough to handle, clean it off, and clamp in a vise. Every time i try the file, it bites. As far as I can tell, no change has taken place. I've been doing this for days, trying to eliminate possible sources of error, and I'm out of ideas.
I'm quenching in about 4.5 gallons of used motor oil in a metal trash can, warmed with a piece of heated steel prior to quenching. I've tried swirling the blade around, plunging it in fast, putting it in slower, everything I can think of. I know there have been lots of threads about this, but I can't seem to figure it out. Any ideas? I live in Boulder, CO if there's anyone nearby. Thanks -Andy
