Helle knife company opinions.
Grateful
Anybody want to share their thoughts, experiences or opinions on Helle knives? How is the laminated stainless blades? Anybody have the Viking model with the carbon steel blade? How are the sheaths? Do they sharpen the same as a Mora?
They look great but I have never handled one so any feedback will be appreciated. I will use it for woods walking, lite bushcraft, hunting and maybe even some kitchen duty.
Excellent knives. I use a Harding. It is light, handle extremely comfortable. Sheath is top quality leather, very nice & secure design.
Blade is tough enough for wood work, but thin enough to slice decently. Holds an edge well. looks very good.
I haven't batonned with it.
I have whittled hardwood & prepared food.
It sharpens like a scandi. The angle is acute enough that you can sharpen with a smaller bevel for convenience, & then every so often grind the main bevel back. Or just take the time to sharpen the main bevel each time, which is what I have decided to do after trying both.
Best points: very light weight, good steel, comfortable handle.
I haven't seen a viking.
I have both a Viking and a Harding. Good knives. It's best to pick in person to get the best looking handle and to eliminate the possibility of getting a knife with the scandi grind's apex off center. Sharpening is the same as with other scandi grinds.
The Viking's carbon blade is not cleaned and polished after heat treat leaving much of he scale and giving it a more rustic look. Balance is more blade heavy than the Harding, but the balance is good. The Harding seems very light as it is center balanced seeming neither blade heavy or handle heavy.
Regarding sheaths, the Harding's sheath secures the knife via flap over a pommel button at tang's end and has a belt loop Americans are accustomed to. The Viking's sheath is of traditional Scandinavian design that is tied on or hung.
The Viking is a traditional Scandinavian knife. The Harding, while a good knife, compromises its roots regarding Scandinavian design. I prefer the Viking, but that's just me and has more to do with aesthetics. Both are good knives.
Viking
Harding
Thanks guys, really good information. I really like the looks of both the Viking and the Harding, not sure which one to try. I don't know of any place close to handle one so ordering is really my best option. I will just keep looking at them until I can choose one.
Jim
I've had their "Odell" fixed blade for several years, excellent quality and one of the best "out of the box" edges I've ever seen.
Seems to hold an edge well also, I've nothing but positive to say about them based on mine.
Sounds like they are worth the money. Thanks for the feedback guys. Anyone want to suggest a alternative knife or company to Helle? I have $100 to spend..
Jim
I have a Lappland Helle knife. It is very nice. The sheath is excellent; and the knife was as sharp as any I have ever seen.
I have the Harmoni and the Scout
The Harmoni is the most comfortable knife I own
It has a extremely sharp out of the box laminated blade that is quite thin
I have not sharpend only stropped
Excellent for woodwork and kitchen
The sheath takes the knife very securely
The Scout is a very comfortable handle SS non laminated blade
as above
I did do some very light batoning thru 2" dried pine branches
And it broke an inch into the handle!
I have epoxied the blade back into the handle and use it for anything EXCEPT batoning
Holds an edge well
I need to sharpen it on a 3000 waterstone soon
They come very sharp.
They slice like crazy. This is typical of outdoors knives traditionally, in that part of the world and elsewhere.
The locals regard Helle as a quality company.
This is very individual, but they look nice to me. I have popped for some customs from Norway and Finland.
Not that it matters, but as with almost all knives from Scandinavia and Finland, they come with a small secondary bevel. Knife makers think they work better that way for general outdoors use. This means they do not fit the definition of the so-called "Scandi grind" as it was laid out by UK "bushcrafters" (saber/flat with no secondary bevel).
If Helle have a small secondary bevel, then it fits into the definition of MICRO
I will look again for the micro bevel
But I do not recall in either knives or any of the Helle blades I have waiting for me to put handles on, having secondary bevels
Helle Blades
They make a very wide selection of blades form laminated carbon to laminated SS, and plain SS
You can buy these blades and make your own handles and but Scandinavian type sheaths
It puts a Helle blade possible at about 1/2 the price of a factory made knife
But you have to do the work
I have the helle alden its a grate knife . All so look at Karesvando and eka they have some grate ones to
I bought 2 of the laminated blades used in their Viking knife. They are easy to sharpen and they are thicker than the laminated Mora blades.
Jim
For the purpose of comparison shopping, the build quality of Helle is on par with Karesuando and the high-end Marttiini knives.
A step down, excellent quality but not as refined or fancy, look at Ahti, Brusletto, Lapin Puuko, and Järvenpää. Another step down and you have the nicer Mora knives and the lower-end Marttiini.
If she's pregnant, she fits into the definition of only slightly pregnant. :p
"This means they do not fit the definition of the so-called "Scandi grind" as it was laid out by UK "bushcrafters" (saber/flat with no secondary bevel). "
But who says UK "bushcrafters" have the final say?
This is a thread all by itself
Can a Scandi Grind have a small Secondary Bevel or a Micro Bevel or must be zero
I have some high end Marttiini's. The build quality is good, but blade steel is not as good as Helle.
Unless it means a specific grind, it is meaningless - just causes confusion.
There is no Official Academie Scandi to define the term. However, it seems to have originated on BritishBlades. They say it is saber and single bevel.
But very few knives are made that way, as the mod of thier Scandinacian forum kept telling them -- with no impact.
One advantage of such a grind is said to be the simplicity of sharpening: just lay the single bevel flat on the stone and grind.
Another advantage is said to be that it is superior for carving wood, but I ave examined many knives used by professional carvers, and they all had convex edges/convex secondary bevels and most were flat, not saber.
Rather than thinking this is some sort of silver bullet, think of it as just another way to make a knife, try it out, and see how it works for what you do.
I have knives from Scandinavia and Finland with secondary bevels, flat ground, concave (hollow) ground full convex, and diamond cross-section knives. I think you need to be specific.
I don't think the Scandinavians will call anything a Scandi grind.
It is unfortunate the Brits couldn't find a better name.
You think I need to be specific
Oh Lord!
Please not the taxonimy of naming a grind
The flame from that is hotter than a blacksmith hearth
I know what I prefer as a scandi, which is a zero grind, and if it has a micro on it thenI can still rest the primary angle on the wood
And I also have plenty of knives from Scandinavia that have quite different grinds according to your list
And dont forget the marketing 'Scandi', which is a shallow saber grind and a fine convexed secondary edge
Better pictures than words.
And with good pictures you almost always see the bright edge line of the secondary bevel on the "single bevel" "Scandi."
Same problem with firearms. That's why you "pattern" a shotgun to see what that maker meant by "Improved" choke.
