Please note that running this program without supervision can cause your computer to not operate correctly. Therefore only run this program at the request of an experienced helper.
AVG is no good anymore, it's been known to be prone to false positives. Either way try running a test as an administrator. My suggesting also is to use malwarebytes, it's detected stuff that my antivirus failed to pick up.
I have to agree, I used AVG for years and I got malware all too often either with the free version or the paid version. Its got holes big enough to drive a truck through, and doing scans it would always bring up files as 'locked not tested'. I moved on and had success with Avast, and now a paid subscription to Trend and it has been working well.
We had Trend Micro on the machines at work, but it would bring those older computers to a crawl. Probably not an issue with a newer computer.
Any sense in using something like this? http://en.wikipedia.org/wiki/Deep_Freeze_(software)
If you can't understand those directions DO NOT try to edit the registry. You'll only mess things up. If you have an actual problem, take your computer to a local repairman and let him fix it. Many virus alerts are false alarms, though. If you're not sure whether you have a virus or not a local repairman could set your mind at rest....
If you want free try MS Security essentials or panda cloud and then pair it with Komodo's firewall. Best bet is to buy a newerish physical firewall. Avast is very resource heavy at least the free version. Malaware bytes works well for removing threats.
Setting up a "boot" Linux Ubuntu thumbdrive is useful as well. Just Google it!
