- Feb 16, 2010
My nephew is working on a project for school. It has to do with simple/complex machines. He is building a ballista that shoots a glider similar to that of DaVinci design. We plan on making the bow out of 18" of band saw blade that is most likely 15n20. The bow will be cut in the middle and about 1" bent 90 degrees and welded to the rails for the glider. Each arm of the bow will be about 8" long.
1. How do I anneal the blade so it doesn't snap when we bend it 90 degrees?
2. How can I heat treat it afterwards so it will hold a strong bend at the weld so when the bowstring is pulled back it will spring back like it should?
3. How do I anneal a band saw blade so I can drill a hole in it?
The last one also applies to how I would drill a hole in a hardened metal such as a hardened blank as well as general how-to knowledge.
If welding is a bad idea, we could drill and bolt, but it be more work.
