The NMSFNO will most likely chop better, having a broader blade which will put the balance more toward the tip. The SAR8 will most likely be lighter in the hand and therefore better for machete like tasks such as slashing. The NMSFNO is also available in CG versions, which could theoretically make one available for less money, although the secondary market markup sort of negates that.
I have an NMSFNO, and like it quite a lot. I would like to have a SAR8 so I could compare them directly with first-hand experience, but the lack of a CG model of SAR8 has prevented me from doing so. I'm not fond of the idea pf paying the several hundred dollar markup for a pretty shiny finish on a knife I'm just going to beat until it's all scratched up anyway.
I think if you combined a normal NMSFNO and a SAR8, you would get the NMSFNO LE, so get that, or get all three![]()
Not having an SAR8 to compare, I will still say the SAR will chop better with the STOCK edges. The NMSFNO stock edge wasNow convexed, it chops like a machine for its size.
Good point - my recommendation was based on the assumption that you would put a workable edge on the nmsfno. I try to never let factory edges bias my thoughts on individual knives, as they have varied so much over time.
I don't have any problems taking a 30 dollar sander to a 400 dollar knife, neither do you. Not everyone is like us though, and not everyone can even reprofile an edge properly. It all depends.
Which one would I rather have? The NMSFNO, with a reprofiled edge chops and batons extremely well. Which is better out of the box? The SAR 8 I'd think. That said, if I had absolutely no ability to reprofile an edge, there are a lot of other knives i'd choose over an NMSFNO, including several bark rivers. With a re profiled edge, it's an absolute beast. The stock edge was useless for it's task.
I know you guys are talking about the NMSFNO CG but there is no reason to reprofile the edge on this one
There are also non-LE satin full convex NMSFNO's out there that have the exact egde as the SAR8. If you compare apples to apples then I would say for a chopper the NMSFNO wins. If you are doing more slashing and machete type work then the SAR8 wins. Factory edges on both of those are GTG.:thumbup:
